We are having problems with installscript Custom Actions running on the SMS 2003 Advanced Client. Our packages worked just fine on the SMS 2.0 client. I made sure that the package was running with Admin Rights. We only notice the problem when a Non-Admin user is logged on to the workstation. I can get VBScript Custom Actions to work just fine.
I can MsgBox ProductName just fine in Vbscript. But I can't do a MsiGetProperty on ProductName in Installscript, and cannot display ProductName through a MessageBox. The MessageBox shows up empty.
Again, these problems only happen through SMS 2003 advanced client. If I run the package manually I don't have any problems. We have 1500+ Basic MSI Packages that are having this issue.
I tweaked the ALLUSERS Property in the Isscript9.msi to equal 1. That didn't help.
Any suggestions?
__________________
Aaron McLean
SBC
SMS 2003 problems with Installscript
am9518
, Aug 03 2004 06:36
Posted 03 August 2004 - 08:46
This is probably the classic "custom action runs in system context" issue. Any terminal services active on this server?
Also, are you running the MsiGetProperty from the user interface or the execute sequence?
Posted 03 August 2004 - 18:32
I don't think any terminal services are running on the server. Why does that matter? I am running the MsiGetProperties from the UI and Exec Sequences. I had no problem at all with the SMS 2.0 client. I have all types of InstallScript CA's. None of them work.
