Hello!
How to store REINSTALL property inside MSI database, but without affecting to first time install?
I suppose to start Minor Upgrade always when it possible, or start first time install.
If I simply set in database
REINSTALL=Feature1,Feature2,Feature3
command-line parameter REINSTALL will be override?
Perhaps, command-line parameter value can override only inside special Custom Action?
Please, eliminate for me all disadvantages of both means.
Thank you.
Store REINSTALL property value in MSI
AntonS
, Nov 02 2004 09:15
Posted 02 November 2004 - 12:58
Posted 02 November 2004 - 14:34
Thank you, Stefan.
It's good article.
Further I suppose, that only way is to set REINSTALL in Custom Action (described in article).
Am I right when suggest to add additional Custom Action type 51 with explicit value of REINSTALL and feature-list, insert it before CostFinalize and add Condition: Installed ?
It's good article.
Posted 02 November 2004 - 16:30
That could work. You may need to put it before CostInitialize, I'm not sure.
