I have set-up a feature installation option for our users to either install onto the Server or a client machine.
During Testing, when I select Server, the template files required are installed as well as a rogue exe which should only be installed on the Client machine.
When I select the Client install, the installation works fine and there are no rogue files installed from the server side.
I have checked the setup design and dont have this exe linked to the server installation option so why would this be getting installed ?
