Posted 14 March 2002 - 12:56
The following article has been published in the Bugs Bulletin in the meantime:
Minor Update Fails for Standard Projects as Full Install
Description:
If you try to create a minor update for a Standard project by changing the package code (which is a Windows Installer requirement), you'll receive the error message "A previous version of this product is already installed..." when you try to install the update. You get this error regardless of the REINSTALLMODE, REINSTALL and ADDLOCAL property settings. This only happens if you deliver the minor update as full install package, not as patch. Basic MSI projects are not affected by this problem.
Workarounds:
Create the minor update as a patch, or use a Basic MSI project.
Status:
InstallShield has confirmed that this is a problem in ISD 7.02.
Created: 2002-01-04 InstallShield tracking number: 1-6UBGA
