I am using the setup.exe install program and it displays a invalid switch error when I try to use the /a option for the admin installation. According to documentation this should work. I would like to use the switch on the command line in the setup.ini. Any answers?
setup error running admin install
laddison
, Mar 28 2001 21:45
6 replies to this topic
Posted 29 March 2001 - 08:32
Which setup.exe are you using? InstallShield's (which tool and version), Microsoft's or Vinga Systems' or ...
Posted 29 March 2001 - 21:18
I will give it a shot and let you know. Are you asking me to do this on the dos command line or in the command line in the setup.ini file.
Posted 29 March 2001 - 22:20
On the command line when you launch setup.exe (i.e. the DOS comamnd line or the Run command from the Start menu)
