We are using Installshield X and we need to convert some ISM projets created with ISWI 2.03.
After the creation of MSI, when we try to install them, we always have error 2715; it seems to be problem with key component but we are not able to solve the problem. Is the conversion impossible?
Thanks in advance
Giambattista
Error 2715 after converting ISM
Paperino61
, Jun 21 2004 11:55
Posted 22 June 2004 - 12:45
| After upgrading an Express 3.x project, building, and running the setup, an error 2715 would occur. This was caused by bad data being incorrectly upgraded from the 3.x project from the prior version. This has been corrected. 1-9FFGU |
You should contact Installshield and ask them what to do. If you send them your project file they might even fix it for you.
Edited by Glytzhkof, 22 June 2004 - 12:45.
