Hi ,
I have build a setup using Installshield professional version 7.01. I want to specify some install conditions. However I could not fine the "install conditions" option. I went through the forum and found that the option should be in -
project settings -> product properties -> Install Conditions
But I dont have any such option ... In project settings I have the following tabs:
Project, Application, Platforms, Languages, Maintenance, Updates, Runtime and Misc. There is nothing like Install Conditions or Product Properties for that matter.
Where do I find Install Conditions ??? I am sorry if the question seems stupid but I would appreciate the help.
install conditions
dsaxena
, May 23 2005 19:37
Posted 23 May 2005 - 21:27
The Install Conditions only exists for MSI projects.
In an InstallScript project you would write your conditions in code, for instance in the OnBegin event handler.
