In the Releases view, is there any way to use a wild card in Supported Versions property? I sometimes have to create newer versions of older releases?
If not, what script uses the Supported Versions property?
Supported Versions
phood
, Aug 02 2010 22:24
Posted 03 August 2010 - 13:28
Not sure what you want to do. In this field you can (optionally) restrict on which previous versions your update can be installed. If you want no restrictions you can leave it empty.
As far as I know the information you enter in this field will end up in system variable IFX_SUPPORTED_VERSIONS which is used in the VerProductCompareVersions() call in event
handler OnSetUpdateMode.
