hello
How do i know that the component is selected in selection tree?
I think it returns some value but i can not find it's location in Direct Editor.
(if the component's name is A then)
I have been used comparison like &A >=3. but it looks like this does not work for subfeatures.
I am using basic so i can not use featuregetdata function.
thank you
selection tree in custom setup dialog
hsong3
, Aug 19 2003 16:58
Posted 19 August 2003 - 18:48
Are you talking about components or features here? (The treeview only displays features, not components)
Posted 19 August 2003 - 20:20
hello Stefan
i meant the features. I am sorry for the confusion.
When user selects certain feature to install, (modify), it should return a value to indicate that the feature is selected to be installed.
where can i reteive this value??
thank you
thank you
Posted 20 August 2003 - 01:34
I found out that if i use MsiGetFeatureState, i could retrieve feature's state. such as,
(this are the 4th parameter value)
-1 no action
1 advertised
2 absent
3 local
4 source.
I have another question related to this custom setup and selection tree.
User selects custom setup and disable most of features. Then he moves back to previous dialog and chooses typical.
I want this user to have default features instead of selected features in his previous action.
do i need to use script to control this?? or is there a built-in function for this situation??
thank you
-1 no action
1 advertised
2 absent
3 local
4 source.
thank you
Posted 21 August 2003 - 11:37
You can use AddLocal and Remove control events to change the selection.
