Hello
Occaisionally but not always when uninstalling an application one or more of my in house dlls are not uninstalled.
I'm assuming this is because Installshield thinks that they are still required by another application (although they are not) or it thinks they are still in use or for some reason it does not have rights to uninstall them.
I have only experienced this on Windows 2000 machines so I'm wondering if it's some kind of operating system issue?
If anyone has any ideas they'd be much appreciated.
Files left behind after ininstalling
seanst
, Jan 06 2003 18:38
Posted 06 January 2003 - 19:14
Are you trying to uninstall with a lower level of privileges than you did for installing? 'cause you should require Administrator privileges for both.
Posted 07 January 2003 - 10:58
I don't think the privileges have changed as this problem does not seem to effect all the installed files. I may for example have installed 10 dlls and installshield will uninstall all but 2 of them. Usually once this happens on a particular machine it will always leave the same 2 files every time you install and then uninstall the application on that machine.
Posted 07 January 2003 - 15:22
This could occur if you've released patch/update installs for your software and are using their uninstall routines instead of the original full uninstall.
However, one sure fire workaround is to modify the default Remove code in OnMaintUIBefore/After and add some additional cleanup just in case.
