Hi all,
Supposing I am installing A.msi and B.msi in this order through a custom bootstrapper...
A and B have distinct package/product/upgrade codes.
I would like the uninstall process to be in a specific order as well, meaning:
if users launch A's uninstall, detect B, if B is still installed, don't uninstall A.
I have tried using RegLocator with B's upgrade code but that table doesn't work with registry keys (only values).
I have tried an entry in A's upgrade table with msidbUpgradeAttributesOnlyDetect and a CA type 19 after FindRelatedProducts, it's still being able to uninstall.
Any thoughts ?
Thank you,
Sophie
Allow uninstall ONLY if...
dtieuf
, May 03 2005 22:45
Posted 04 May 2005 - 00:12
You should be able to find B's upgrade code in the registry, or some other unique key for B in the registry, and set this to a property.
You can then add this to A's logic and pop up an error when this property is set.
Posted 04 May 2005 - 14:00
You want to call MsiQueryProductState with the the product code of B in A's uninstall.
http://msdn.microsof...roductstate.asp
Make it an uninstall action and check for a return of INSTALLSTATE_DEFAULT.
INSTALLSTATE eState; eState = MsiQueryProductState( szProductCode ); switch(eState) { case INSTALLSTATE_ABSENT: case INSTALLSTATE_ADVERTISED: case INSTALLSTATE_UNKNOWN: // Product is advertised or not installed, proceed return S_OK; case INSTALLSTATE_DEFAULT: // Product is still installed return E_FAIL; case INSTALLSTATE_INVALIDARG: // malformed product code ASSERT(FALSE); return E_FAIL; } |
