I have 5 Installers, each of varying sizes.
2 are too big to fit on the CD with the other Three - so however i shuffle this i need to build it over roughly 2+ CDs
Now i know you all say "Use a DVD!" - if i could i would -but the people who will be getting this installer will not have dvd drives most likely (!)
So really i just want some advice - how would i setup an autorun which can go
msi1: on this disk
msi2: on this disk
msi3: on this disk
msi4: please insert disk 2
msi5: please insert disk 3
If someone can point me in the right direction that would be great. I realise about the autorun,info and using a html file to make a pretty autorun - just trying to get the last part of "please insert cd2" then on cd 2 it installs the application and then goes back to "please insert cd1" and carries on.
Thanks guys (Yet again!)
Installation over Multiple CD
lizii
, Jan 31 2007 10:59
Posted 02 February 2007 - 12:09
Well i got around this problem using a .NET application which then calls each of the files.
Now anyone got another piece of advice....
As you can imagine - i have to change CDS but the .NET application immediately complains when i take the CD out.
Any advice of how to stop that? Or is there no way around this problem?
I thought about making an auxilliary application which will load it somewhere then run it and close itself - but then the problem remains that you have that file floating around their system.
