Hello,
I am developing an InstallScript Project (11) within Visual Studio. Net IDE.
I also added a new Visual C++ (Console Application) project.
My question is: how can I use ( if is possible ) a function defined inside a .cpp or .h file form the VisualC++ project inside my InstallShield script ( setup.rul file )?
Thank you for any reply.
Visual Studio Project
Ioana
, Jul 26 2005 15:13
Posted 26 July 2005 - 22:01
Your C++ output would have to generate a DLL or EXE that you could in turn use as a custom action.
Posted 27 July 2005 - 06:53
Thanks for your reply.
This is exactly what I wanted to do: avoid using a DLL / EXE or work a
custom dialog within the VisualStudio IDE.
I thought that, if the IDEs are integrated I could find a relation between
the projects.
It seems that this is not possible.
Thanks again anyway..
the projects.
Posted 27 July 2005 - 14:57
Apologies, my reply applies to MSI projects, not to (pure) InstallScript projects. But still you need to build some sort of executable (EXE, DLL). InstallShield cannot compile your C++ source code into a install script.
