In the 5.x versions of InstallShield it was possible to set the "Run in separate memory" option for shortcuts. I did this by using the AddFolderIcon function and passing in RUN_SEPARATE_MEMORY flag in the last parameter.
Now in the 6.x versions, if I specify the same flag, nothing happens. I checked in the index for the manual and in the help for the flag. It's listed but when I go to the page to read about it, there is no reference to it.
Is this no longer an option? I need this option for some 16-bit programs.
Run in separate memory shortcut option
winterwheat
, Feb 05 2002 00:05
