Is it possible to have an edit box control that's tied to a property appear in the UI initially empty?
The problem I'm having is that the edit box displays the
property value, and properties have to be initialized. The closest I've come to a solution is to initialize the property with a space (" "), but this is unacceptable, since the edit box appears empty, but if you tab to it in the dialog, the cursor position is after the space. ugh.
any ideas?
thanks
CM
