We have several .wse files in our appliction. We have a licensed version of InstallShield Professional.
I heard that to convert from .wse files we need either InstallShield Premier or AdminStudio. Is that so?
Could someone please confirm.
Thanks in advance.
Conversion of .WSE files to InstallShield files.
Posted 28 August 2013 - 10:03
Posted 29 August 2013 - 12:30
I can't speak for AminStudio, but I have InstallShield Premier and wasn't aware of a built-in Wise converter. I double checked the help though and didn't find any references to it.
Posted 04 September 2013 - 16:44
There's no automatic converter. But AdminStudio has a Repackager which you can use to detect the changes the Wise setup makes on a clean test system and build a MSI setup from this. (Note that you can't build a InstallScript project this way. The result would be a Basic MSI project).
InstallShield Premier (up to version 2012 Spring) also had a Repackager, which ownders could downöoad separately. This has been removed in version 2013 and is now exclusively in AdminStudio.
