I want to know what msi functions(if any) could enable me to copy a file to the source directory to enable it to overwrite the one in the source directory with another file. I know there is a function called msiGetProperty and i think i can get the source directory using that but it seems difficult.....
What i want to do is to copy an updated readme file into the project automatically. So my custom action will copy the updated readme file and overwrite the one in the source directory. Can i do this using my dll or any other way?.
Copying file to SourceDir at runtime
James_dean
, Jul 15 2005 13:01
Posted 15 July 2005 - 14:37
Sorry for asking, but can't this be done with a batch file prior to running the setup?
I suppose you could use the [SourceDir] property as you suggest, and then use a script to copy the file to this directory (though I have never tried it). You would probably need an immediate mode custom action run after the ResolveSource action.
The code would be something like this:
Dim objFSO Set objFSO = CreateObject("Scripting.FileSystemObject") SourcPath = "D:\WhateverPath\File.txt" DestionationPath = Session.Property("Sourcedir") fso.CopyFile (SourcPath, DestionationPath) |
Posted 19 July 2005 - 12:14
A batch file would even do........can you overwrite the source directory inside the setup exe with a batch file. If so...how?
