Hello!
Is there a possibility to add files to the support files during the setup execution or UI Sequence? Because I need these files during uninstallation and does not know them on build process.
Especially I want to add registry information from additional reg files and use them to delete the registry data on uninstall.
Or do I have to install them for instance in INSTALLDIR?
Thanks in advance.
Support Files
Alibaba
, Nov 28 2008 14:05
Posted 12 December 2008 - 14:42
You can't embed files into the msi file during execution of the same. You'd better stopre these files in INSTALLDIR or elsewhere on the target machine.
