I use ISPSE 6.3. I have used it with and without the latest updates from IS.
When I rebuild a particular VB project, the process works fine. I then install it on Windows 98SE, which also works fine, then I reboot. The network logon prompt appears, I log on, then nothing happens. The desktop does not appear, then I get an Explorer Invalid Page Fault shell32 msg. CTL-ALT-DEL is the only way to shutdown.
I have created a new IS project, and experience the same problems. I have used IS on both Windows 2000 and Windows 98 to build the projects. I have tried an older project; that rebuilds, installs, and the PC reboots fine.
I am at a loss as to where to turn. I have tried loads of fixes/procedures suggested on various websites, and the result is always the same.
By the way, I reload an image of the test machine partition everytime before I install the software, so it is always a "clean" system. Internet Explorer 5 is installed, but no MS Office applications.
My project is installing the IS components VB6 Runtime, DAO with ODBC and Jet, and MDAC. I have used this combination in the past with no problems.
Please help. I hope this makes sense and is not a tall order
Mike
