I have some C++ dlls i.e. msvcm80.dll, msvcp80.dll, msvcr80.dll in the Application target folder that I need to put in the destination computer.
Previously when I was using INstallscript MSI this was working fine, but after converting to pure Installscript, it started giving the following error -
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Users\mayurb\AppData\Local\Temp...
R6034
An application has made an attempt to load the C runtime library incorrectly.
Please contact the application's support team for more information.
I also tried adding Merge modules for the C++, but that didn't help.
Does anybody know the solution?
Getting a C++ dll error in installscript project
Mayurb
, Sep 10 2008 21:45
Posted 11 September 2008 - 20:20
I solved it.
Actully previously i have not converted the project through conversion wizard but I had created new one and then added all the existing functionality, and then I started getting this error.
I was able to resolve this by converting the installscript MSI proj to installscript with the conversion wizard.
