i use Visual Studio 2003 to build my setup.
I have a checkbox page with 2 checkboxes
To test the values i have a textbox page that
follows the checkbox page to display
the selection.
I did the following:
On the Checkbox Page:
Checkbox1Property set to TESTPROPERTY
On the Textbox Page:
Edit1Value set to [TESTPROPERTY]
I thought I will see the selected value in the
textbox?
Is there any other way to "Debug" the properties?
Thanks for any help
Frank
How does Properties work?
stegerwald
, May 12 2005 08:30
Posted 12 May 2005 - 14:33
See http://msdn.microsof...up/controls.asp for information on Checkbox controls.
Basically checkboxes can only be used to do the following things:
AddLocal ControlEvent, AddSource ControlEvent, Remove ControlEvent, DoAction ControlEvent, or SetProperty ControlEvent
I would recommend setting a property, and then conditioning the contents of the edit box on value of that property.
Posted 13 May 2005 - 08:28
If you want to associate the property with an edit box, don't put it in square brackets.
