I created a new dialog with some checkbox. But when I click at runtime on the checkbox it dont change the status (checked, unchecked).
Any Ideas?
thx Mike
Checkbox dont work
mike_mc1
, May 27 2002 17:55
Posted 27 May 2002 - 21:34
Make sure that there is nothing else in the dialog overlapping your checkbox. Depending on the tab-order it might be in front of your checkbox. Trying to click the checkbox always clicks the other (overlapping) dialog element.
I had this problem with a radio button group which was always overlapping a checkbox.
You could try to see if your checkbox works at all by tabbing through all elements of your dialog (when the setup is run - not in the dialogeditor in ISWi or ISD). When you see your checkbox is focused then press "space" to select/unselect.
h.teichert-ott
