I am using Install Shield 2012 Spring - Premier Edition , version 19.
I have an Install Script MSI project. To localize our product , I have added some languages in the Setup Languages field under "General Information" and selected some languages in the UI languages under "Releases".
All the settings are correct and proper and i am building the release correctly.
When i tried to build the project ( Out 0f 10 times , once or twice it is successful) , most of the times i get the following errors.
Its building successfully if i include only one language.
Error opening MSI database "<prodpath>\Product\Release\DiskImages\DISK1\1043.msi" -4092. The number of the msi varies though.
Some times i get Internal build error also.
I tried with different combinations of languages but ended up in getting the same error.
I have enabled "Keep unused directories" to yes. But no change though.
Checked many forums and sites but no help and i can see that many people face this issue too.
We are blocked on this and Please help in fixing this issue ASAP.
Do i need to add/change anything more ?
