Hello -
I am trying to check if Internet Explorer is opened during my installation and block installation from proceeding further until IE is closed.
I have written a VBScript custom action to check if IE is opened and then display a message. I am calling this CA during on-click event of Install button in ReadytoInstall dialog. But after displaying the message, installation keeps progressing. How do I block the installer from proceeding further until IE is closed.
That is, clicking on Install should do nothing until IE is closed.
Thanks for your time,
Condition check using VBScript CA
RickDavis790
, Jul 19 2012 12:04
Posted 24 July 2012 - 14:34
you have to set a property in your action to reference in the condition. Example:
function CheckServicesState(hMSI) string szServiceName, szMessage; number nServiceType; begin szServiceName = "Explorer.exe"; LoadStringFromStringTable("MyString", szMessage); ServiceGetServiceState(szServiceName, nServiceType); if (nServiceType = SERVICE_RUNNING)then MessageBox(szMessage, WARNING); MsiSetProperty(hMSI, "ServiceRunning", "1"); else MsiSetProperty(hMSI, "ServiceRunning", "0"); endif; end; |
Then in your condition on the ReadyToInstall dialog
change your condition for end dialog to:
| OutOfNoRbDiskSpace <> 1 AND ServiceRunning <> 1 |
This should prevent the dialog from progressing and allow them to close the app and click Install again. Hope this helps!
** its worth noting the detection code above probably wont actually find internet explorer. But the important tidbit is the MsiSetProperty bit which should still help you. **
Edited by overlordchin, 25 July 2012 - 16:21.
Posted 26 July 2012 - 15:25
Also note my example was installscript. For VBscript i believe it is
Session.Property "MyProperty" = Value |
or something along those lines
Posted 06 August 2012 - 10:26
Thank you. It worked.
Actually I was trying with wrong condition. something like ServiceRunning = 1 instead of <>. Your suggestion helped me to try this.
