I am having an issue with an upgrade installation. The upgrade seems to work properly, but I have a need to modify the existing shortcut to Uninstall the product. I am using the IDE resource panel to create a shortcut that is identical to the existing uninstall icon, but adds an UNINSTALL parameter to it. "Replace existing shortcut, if found" is set to Yes, however it is not actually replacing it. If I run the upgrade, the old icon remains. However, if I delete the previous uninstall shortcut manually, the new shortcut with the new parameter is installed. Is there a bug with the replace feature that I should know about?
Any suggestions are appreciated.
Dave Wilkinson
dave.wilkinson@givemepower.com
| Quote |
