Okay, I need some help. Currently our company is shipping a compressed and uncompressed image of our product. The problem i am having is with the compressed image. One of the problems with having a compressed image is that you cannot directly edit the compressed MSI. If you do, then the size of the MSI drastically changes. So, I assume that the only way to modify a compressed MSI is the uncompress it ( do an admin install ), make your changes ( add files, edit tables, whatever ), then recompress it. So does anyone know how I can recompress the MSI with my changes?
We need to have this ability for our customers if they decide they want to add or make changes. I see that there is a utility called makecab.exe and msidb.exe which will create the cab file and insert the cab file into the MSI ( i know Installshield uses makecab.exe, but they don't document on how they use it), but I am having problems just generating the cab file itself. Does anyone have any ideas on how to do this? I can't figure it out. I will be recompressing hundreds of files and mulitiple directories.
Any help would be greatly appreciated. I am using ISWI 2.01, but I don't think that matters.
thanks in advance,
-daren kobata
Recompressing an MSI package after uncompressing?
darenko
, May 14 2002 17:44
Posted 14 June 2002 - 11:33
1. Create a text file test.ddf and enter all file name to be included in the cab in the correct sequence order. Each filename should be on a seperate line
Ex:
SALPLAN.HLP
Readme.txt
Olemsg32.dll
2. Copy the “test.ddf” file to the folder contaning the files to be include in the cab
3. Run the command makecab /V /F test.ddf. This will create “1.cab” file in “.\disk1\” folder
4. Rename the 1.cab file to the cab filename you require.
Ex:
SALPLAN.HLP
Readme.txt
Olemsg32.dll
Gunavelu
