I have an install inwhich I need to use a Dll's interop for my program to communicate with the main programs dll. I need only the interop to be moved over on the install, but for some reason I am also getting the dll copied over? My build report does list the dll in the dynamic link section with the component listed as _68392DC487F844E5A827061D7BC63419. What is adding the dll to the package???? I am using DevStudio 9
Unwanted DLL
Island28
, Feb 23 2005 16:34
Posted 24 February 2005 - 08:37
If you use dynamic linking it will add all files from the specified folder to your setup. Use static linking to avoid this, or define an exclude in the dynamic link settings.
