Posted 08 July 2002 - 01:48
I had to do this in my install as well. I had a lot of trouble getting the the correct URL in the shortcut, and the best way to do this (I found anyway) was to actually create a shortcut file (shortcut.URL) and then move this into the correct shortcut folder on the machine.
Firstly, copy the URL that you want to appear in the shortcut.
Then create a new shortcut (right click and choose new->shortcut). Then paste in the URL that you need.
You will then have an internet shortcut.
I then created a seperate component, and included this shortcut (shortcut.url) into the component files. Note, use a dynamic link because the program i use the create my setups with (Install Shield developer 7) does not like to link in a shortcut, but in a dynamic link it works fine.
Then set the destination directory for that component to the [programmenofolder] YOUR test Project ... etc.
