I have added some custom code during uninstall in OnUninstall. it never gets called. why? it is 11.5 installscript project.
OnUninstall()
ramalaks
, Feb 14 2006 22:30
Posted 28 February 2006 - 20:51
The OnUninstall event is called when the setup is run with the -uninst switch, in this case this is the only event that will be called.
That's copied straight from the comments above the function.
You may try adding your script to the OnMaintUIAfter with an if (REMOVEALLMODE) then statement.
