Hi, and one more problem,
after installation there is a link in the Add/Remove item in the control panel, where support information are provided. There is only show the version number I entered in the setup project options. How can I fill these dialog with more details or what can I do that this dialog will disappear. I filled all possible properties in the setup project properties.
Thanks for your help
Mõbius
Setting support information
Mõbius
, Apr 16 2003 09:40
Posted 16 April 2003 - 19:57
To modify what is put in Add/Remove by default you need to access the registry directly. Something like this modifies the name, <> means insert your info here:
In OnFirstUIAfter do something like:
Check out the post by Clareb22 on Support Information for a link to other parameters you can modify this way.
RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szKey= "SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{<PROJECT_GUID>}"; nRet = RegDBSetKeyValueEx(szKey, "DisplayName", REGDB_STRING, "<NEW NAME>", nSize); |
Posted 22 April 2003 - 19:03
Under ISD 7.04 look under General Information: Add/Remove Programs, all the information you could ever want to modify is under here.
Posted 25 April 2003 - 16:11
Dagostini: what you say is correct for InstallShield Developer 7. However this forum is about InstallShield Professional 7. Therefore prozacrefugee's suggestions is the right one.
