Hi All,
I have this setup which is replacing an EXE file that is already running. so before is start the setup i need to manually goto task manager and end the process and then continue with my setup. is there a way by which i can detect if a process is running in the task manager and stop it thru code in Installshield Professional 6.2. Please Help.
Thanks in advance.
Regards,
Siva
End Process
siva
, Sep 01 2004 13:21
Posted 01 September 2004 - 15:10
Check out this "List and Shut Down Running Applications" example.
Edited by Taco Bell, 01 September 2004 - 15:11.
