I have a project that used to have EN-US and JP as language choices. I have removed JP as a language option and now it no longer shows the string table or the JP dialogs. However when you run the compiled installer it still prompts you and allows you to select Japanese as a language option. I do not see a dialog that I can customize to avoid this behavior. What can I do to remove the prompting?
internationalization removal
overlordchin
, Feb 18 2011 17:54
Posted 18 February 2011 - 19:54
Found it.. You have to manually step through the release wizard to remove this. If you just rebuild the existing release it will continue to attempt to include the additional language/s. As soon as you step through the previous release it throws up a warning dialog saying a language has been removed and the release will only contain the languages that are still available within the project.
