Hello to you all,
This is my first post as I am new to installs, but I need to install an ASPI Layer for a product that is required to have a CD/DVD writing feature.
Not being overly familiar I have been reading around (and found this site among others) that make me wonder if such a merge module exists that I can use. Otherwise, can I make one from the files I have or should I simply launch a silent install depending on the system's requirements?
I am using Developer 9 with a Basic MSI project as a basis for my project.
Regards,
Gareth
ASPI Layer Merge Module
Gareth at Serif
, Jan 20 2005 13:22
Posted 20 January 2005 - 14:49
I'm not aware of such a merge module, but you may want to contact the manufacturer of the software and ask whether thery provide a merge module for it.
Otherwise you could call the ASPI setup as a custom action. You can either add this action directly to your setup, or place it in a merge module to be able to reuse it in other projects.
