I add a database file to my setup and set the permissions to be modify/read&execute/read/write...I run the installation and the file gets added but only with the permissions to read&execute/read/write...there is no modify permission checked so i have to do this manually...Is there a reason for this or a way to fix it so modify is checked?
Jason
File Permissions problem
jasonVIS
, Aug 02 2004 17:34
Posted 03 August 2004 - 03:35
Did you author the LockPermission table?
http://msdn.microsof...sions_table.asp
Edited by Glytzhkof, 03 August 2004 - 03:39.
Posted 03 August 2004 - 19:31
in the LockPermissions table, I have the file permissions showing as 131519
