Install from the Web Setup (using InstallShield 11.5):
a CA called "launch_CDS_setup" launch an exe at the end of the setup. The problem is the path to this exe can't be found by the installer. Here is the CA table:
launch_CDS_setup 242 [SourceDir]xyz.exe
...doesn't work!
launch_CDS_setup 242 [SOURCEDIR]xyz.exe
...doesn't work!
launch_CDS_setup 242 http://172.31.193.18...etupDir/xyz.exe
....doesn't work!
xyz.exe is at the same place than the main msi file (in http://172.31.193.189/mysetupDir/)
if I try
launch_CDS_setup 242 c:\xyz.exe
....that work
Why
....doesn't work???
lavocat
, Mar 20 2006 13:04
Posted 22 March 2006 - 09:16
In other words, my question was: "how can I run, from a CA, an exe which is on the web?"
Posted 22 March 2006 - 10:47
I don't think that's possible. You could add the exe to the Support Files view and run it from the temp folder.
