How about enclosing everything in ()
(CODE1="PK12H" Or CODE1="PK34H" )
If that doesn't work you ocould always try a Custom Action using some VBScript example below:
Make sure that you create a Property in the Property Manager called MOVEALONG. I would also set its value to No.
Option Explicit
Main()
Sub Main()
Dim sVar
sVar = Session.Property("CODE1")
If (sVar = "PK12H" OR sVar = "PK34H") Then
Session.Property("MOVEALONG") = "Yes"
Exit Sub
Else
MsgBox "Wrong Code, try again!"
End If
End Sub
Now in the Dialog Editor set the behavior on the next Button as follows
Event Argument Condition
DoAction CA Name 1
New Dialog NextDialog MOVEALONG = "Yes"
Good Luck
Kurt
