HI, I have created Setup_A for a given project. At a later point, I need to build a new setup, which I'll call Setup_B. Nothing has changed between Setup_A and Setup_B except for some of the dates of the modules included in the build. In Setup_A the files were dated 2/8/2008, in Setup_B, the files have been modified, and have a date of 3/11/2008.
I install Setup_A, and see all expected files. I then install Setup_B and I do receive the "this will perform an upgrade" dialog, then continue on with the install.
When Setup_B has been installed, I still see the 2/8/2008 date for the modified files, not 3/11/2008.
I thought I had everything covered. When I did the build for Setup_B, I did not change anything, just made that the components reflected the 3/11/2008 date (which they did), I did not change product version or product code (hence a minor upgrade), so why don't I see the modified modules with the 3/11/2008 date???
Any help would be greatly appreciated.
Thanks, Tim
Doing a minor upgrade install
thil43
, Apr 23 2008 15:07
Posted 24 April 2008 - 14:52
If these files are versioned (DLLs, EXEs, and the like) Windows Installer doesn't look at the date, only at the version. Make sure you always increment the file version.
