I have created a patch using the patchdesign view. The Paths to the previous setup are setup as absolute paths such as c:\installer\... The patchcreation reports no erros and no warnings. But the patch doesN't patch any files.
In the patchcreation.log I find entries that the source files are missing the desired path to the file looks like
c:\installer\.\program files\application...
So installshield put a dot between the relative part and the absolute part of my previous installer.
How can I prevent installshield from using theese wrong filepaths?
wrong paths to files when patching
HeikoFolkerts
, Sep 09 2005 12:30
6 replies to this topic
Posted 10 September 2005 - 10:10
The first thing I would check is that the source and target installations have the same media layout. That is dont use compressed files for one setup and uncompressed files for the other.
Posted 12 September 2005 - 09:22
It seems that it was a mistake by me. What irritated me was the notation of the path with the dots. Andyour tip may be right. Maybe I setup to use the compressed releasetype instead of uncompressed as in the old one.
thanks!
Heiko
thanks!
Heiko
Posted 13 September 2005 - 04:31
If you have used compressed files, you need to create admin images of your setup to be able to create a patch. I prefer using compressed files and then use the admin image for patching rather than creating setups with uncompressed files. That's just a matter of personal preference though.
Posted 13 September 2005 - 06:35
what do you mean by making admin images? How can they be made?
Heiko
Heiko
Posted 14 September 2005 - 03:17
From a command line:
setup.exe /a
or
msiexec /a InstallFile.msi
If supported by the setup this will uncompress all CAB files inside the compressed setup and give you a "network image" of the files.
setup.exe /a
or
