Hi everyone!
I have a problem with the uninstallation of a program:
When i install the software with admin-account A and then log on with an other admin-account B, I'm not able to uninstall the software. The program does not appear in the add/remove programs list and msiexec /x... does also not work (it says the software is not installed and the log file is empty).
When i log on with the account with which the program was installed, the uninstallation works as usual.
I really wonder how this is possible, because there is an entry in
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
Can anyone tell me how to enable uninstallation for any admin- account?
thx
uninstall problem
madvillain
, Jun 16 2008 10:00
Posted 17 June 2008 - 16:30
Make sure the ALLUSERS property is set to 1 when you install.
Posted 24 June 2008 - 15:50
| QUOTE (Stefan Krueger @ 2008-06-17 16:30) |
| Make sure the ALLUSERS property is set to 1 when you install. |
thanks for your advise stefan, but the problem is, that the program is already installed on >400 notebooks (and it was installed with different admin accounts...).
i think i will remove the program via snapshot now, but i'd prefer msi..
greets, alex
