I am developing a setup for a product using InstallShield Professional v5.5.
From my setup, I want to check whether Microsoft Visio and Oracle Client exits on the target computer and write the same message into the log file.
1. How do i know the existence of these softwares through my script.
2.How to write the appropriate message into the log file.
Jaya
Check for other softwares
Jaya
, May 29 2006 13:57
Posted 08 June 2006 - 20:34
To see if Visio is on the computer check for the existence of the following registry key:
HKEY_LOCAL_MACHINE / SOFTWARE / Microsoft / Visio
Under this key there is a string value named "CurrentlyRegisteredVersion", whose value is the version installed on the computer.
I suspect the registry key for Oracle might depend on the version installed, so I can't help you with that.
As far as writing to a log file, here is some sample code from the InstallShield help files:
OpenFileMode(FILE_MODE_APPEND);
OpenFile(nvFileHandle, "C:\\Example", "Myfile.txt");
WriteLine(nvFileHandle, "Line I am adding to my file.");
Note: if you have just created a file using the CreateFile function, do not open the file. It is already open in append mode.
