We are using Installscript for building the setup for our application.We have a problem with add/remove program in control panel.
When we try to uninstall our application using add/remove programs in control panel, it is uninstalling our application successfully. But it leaves our application entry in the add/remove programs list even after uninstallation.This is happening only on XP Machine. On 2000 and vista machines, application entry gets removed from add/remove programs list after uninstallation.
Is anyone having any idea why this is happending and is there any workaround to fix this problem.And what stage the entry from Add/remove programs is deleted.
Thanks for your help in advance.
Entry not removing frm Add/Remove list
rjprasadch
, Jan 08 2010 11:21
Posted 08 January 2010 - 15:42
In some instances, the Add/Remove Program entries aren't automatically updated to reflect the uninstall results, so does the problem continue even after the dialog is closed & re-opened?
Posted 13 January 2010 - 10:51
| QUOTE (Taco Bell @ 2010-01-08 15:42) |
| In some instances, the Add/Remove Program entries aren't automatically updated to reflect the uninstall results, so does the problem continue even after the dialog is closed & re-opened? |
Thank you very much for the reply. I have closed the Add/Remove Program dialog and opened, still that Application entry is there in the add/remove list
I deleted application registry entry from the registry, then the entry is removed from the Add/Remove list.
Can you please advise us to proceed further, like whether i have to remove the registry entry after uninstallation to fix the problem or do you have any other suggestions.
Posted 14 January 2010 - 17:00
You normally don't have to manually remove the associated registry entry, so I'm not sure then why you're experiencing this problem. Certainly that would be a workaround.
To try and understand why it's happening though, I would recommend running the InstallShield Log File Viewer from the IS Tools to review the included registry operations. I would also try running say Process Monitor from Sysinternals to watch the registry changes and see why it may be failing.
Hope it helps and good luck.
