I have created a custom action that renames a directory during an install. The action is fired when you click the 'Next' button an a particular Dialog and based on a property value. IS there anyway to set this action to run when passing command line options to msi for a silent install? This is version 8 Developer.
Thanks...
Running Custom Action during silent install
roso67
, May 17 2006 16:56
Posted 18 May 2006 - 00:30
Sure, just put it in your exec sequence as well and make it install on condition of a public property that you pass at the command line.
Posted 18 May 2006 - 04:42
Or instead of using a property passed at command line you may use 'UILevel' property.
ankur tyagi
