Google's translation tool to translate into English from Japanese, so I'm sorry if difficult to understand English.
When setting up a second OnMaintUIBefore () function in the once components are installed
Removal from the normal installation and start trying to create a setup.
Installation of the component Uninstalling and of itself is going, uninstall
Information related to the work need not be set up.
Write the uninstall information about the registry MaintenanceStart () can be solved by calling
The result is far, C: \ Program Files \ InstallShield Installation Information \ (GUID) to
A copy of the setup is done.
Internally, the flag has a value (or installed or uninstalled) will work if I change?
And thought, but also the function of such a system could not find the variable.
(First of all I do not know whether the flag …)
Someone you know that this area had more advice would be appreciated.
function OnMaintUIBefore ()
begin
/ / Default status of the set-up
SetStatusWindow (0, "");
Enable (STATUSEX);
StatusUpdate (ON, 100);
/ / Delete all of the components
ComponentRemoveAll ();
ComponentTransferData (MEDIA);
/ / Continue the installation
OnFirstUIBefore ();
/ / Uninstall information write to the registry
MaintenanceStart ();
/ / I want to copy the "Setup.exe" under the "C: \ Program Files \ InstallShield Installation Information "
end;
Edited by GreatefulDead_Hiro, 19 December 2008 - 02:47.
