I want to call MsiInstallProduct API to launch an InstallScript MSI project in silent mode, without using the setup.exe.
But when calls the function, it always show an error dialog.
How should I do?
Thanks.
Kevin
How to use MsiInstallProduct?
Kevin Liu
, Jan 09 2004 08:04
Posted 09 January 2004 - 09:02
Use msiexe.exe to launch your setup:
msiexec.exe /i "TheMsiFile.msi" /qn
Edited by Glytzhkof, 09 January 2004 - 09:03.
Posted 09 January 2004 - 09:06
Ah, sorry. Installscript project... The above command line will work for a basic msi file.
I guess you would need to create a response file for the setup and then run the setup with a command line. I think it is possible to pass command lines to the msiexec command from the setup.exe command line by adding /V. Sample:
setup.exe /V"/L*v c:\test1.log"
