I have a custom dialog with a BACK, NEXT, CANCEL buttons. When the cancel button is clicked, the OnCanceling() function is called. But if I try to close the dialog by clicking on X button on the top right corner, no action takes place. My code does not recognize DLG_CLOSE at all.
This is my function below..
Close buttons on Custom Dialo not being recognized
vishwa
, Oct 01 2004 21:50
Posted 01 October 2004 - 21:50
#define SD_CUSTOM_DB_ASK_OPTIONS "DBAskOptions" #define SD_PBUT_CONTINUE 1 #define SD_PBUT_EXITSETUP 9 #define SD_PBUT_BACK 12 function NUMBER MyCustomDialog() STRING szDialogName; BOOL bDone; NUMBER nResult, nCmdValdue; begin szDialogName = "SD_CUSTOM_DB_ASK_OPTIONS"; EzDefineDialog( szDialogName, ISUSER, SD_CUSTOM_DB_ASK_OPTIONS, 0); bDone = FALSE; while (bDone=FALSE) nCmdValue = WaitOnDialog(szDialogName); switch (nCmdValue) case DLG_INIT: MessageBox("init", INFORMATION); case SD_PBUT_CONTINUE: MessageBox("continue", INFORMATION); bDone = TRUE; nReturn = NEXT; case SD_PBUT_EXITSETUP: MessageBox("cancel", INFORMATION); bDone = TRUE; nReturn = CANCEL; case SD_PBUT_BACK: MessageBox("back", INFORMATION); bDone = TRUE; nReturn = BACK; case DLG_CLOSE: MessageBox("close", INFORMATION); bDone = TRUE; nReturn = CANCEL; case DLG_ERR: MessageBox("Internal dialog box error", SEVERE); bDone = TRUE; endswitch; endwhile; EndDialog(szDialogName); ReleaseDialog(szDialogName); return nReturn; end; |
Please let me know what I am doing wrong. The "case DLG_CLOSE:" never gets executed when I click on the close button. All the other cases work fine.
Vishwa
Posted 06 October 2004 - 22:29
Substitute the following code for DLG_CLOSE
case DLG_CLOSE: // The user clicked the window's close button.
Do (EXIT);
Do (EXIT);
Posted 07 October 2004 - 15:08
Still, nothing happens. Actually, the execution does not reach "case DLG_CLOSE" at all even when I press the Close button on the right hand top corner.
I am sorry that I did not explain properly in my initial mail. Actually, in the code that I have provided, when I press the close button, it does not display
MessageBox("close", INFORMATION).
So, the script is actually not recognizing that I have pressed the CLOSE button.
Any help is highly appreciated.
Vishwa
Posted 08 October 2004 - 14:10
Vishwa,
If you look at the example in the InstallShield Help for EzDefineDialog() you will see that they use a Repeat-Until bDone; loop. You are using a While-Endwhile loop.
Also, you defined a Numeric variable as nCmdValdue, but typed it in your code as nCmdValue. If you try to compile it as typed, there should be a compile warning about an undefined variable nCmdValue..
As the example in the Help file demonstrates, use
Do (EXIT);
Do (EXIT);
Posted 11 October 2004 - 15:21
Vishwa,
After trying the code I sent you, I have to admit that the default code to close the form does not work. That code was:
Do (EXIT);
What I discovered was that while working with the dialog 'Askpath', I noticed that the form had an invisible button in the lower left corner of the form. This button has a Name Porperty of 'ControlId_2' and a Control Identifier of '2'. So what I did was to add the lines:
#define SD_PBUT_CLOSE_FORM 2 // The invisible button on the form
case RES_PBUT_CLOSE_FORM:
MessageBox ( "CLOSE - Here I is!" , INFORMATION ); // Testing message
Do (EXIT);
And the form responds!
I am at a loss as to why the default reserved work DLG_CLOSE does not respond directly in this version.
Do (EXIT);
Do (EXIT);
Posted 11 October 2004 - 19:59
Hi Ozone,
Thanks a lot for your discovery. I too found the C button at the left end of my custom dialogs. I added the case to handle that button, and everything works like a charm!
Thank you once again,
Vishwa
