my component contains a .ini-file.
I have a key, which I change depending on [INSTALLDIR]
Example:
[cfgdata]
mykey=[INSTALLDIR]
After installation, the key is changed to:
[cfgdata]
mykey=C:\whatever\subdir
Problem: This ini-file is read as a java.property by a standard application which i cannot redesign. I need doublebackslashes like c:\\whatever\\subdir so the java-app can read this keyvalue.
Any ideas???
Tnx in advance!
Greets
Jens
Double backslash in .ini file - how?
jdannenb
, Oct 09 2002 15:39
Posted 10 October 2002 - 12:09
You can do this by using an install script custom action (for file edit) after copying the ini file.
Copy the INSTALLDIR string and replace the slashes with double slashes. In install script string you will have to give "\\\\" for "\\". After this, use the FileDeleteLine and FileInsertLine functions to replace the line.
- vkj
- vkj
