I have a InstallShield Express v4.0 SP1 app that does a complete install if a previous version doesn't exist or updates if the previous version does exist. I have MinVersion and MaxVersion turned off b/c I want every version patched to the new release. This all works fine, except I have noticed that the previous versions are not being removed from the Add/Remove Programs list. Is there a way to correct this?
Update not removing Add/Remove Instance
Daywalker46410
, Aug 30 2003 00:49
Posted 30 August 2003 - 07:55
did you change the ProductCode but keep the UpgradeCode? Also double check that you specified the correct upgrade code
Posted 30 August 2003 - 13:23
I'm using the same ISE file each time and just re-generating a Product Code and re-building. This ensures that my Upgrade Code is the same. Do I have to have MinVersion and MaxVersion on?
Edited by Daywalker46410, 30 August 2003 - 13:26.
Joe Cody
Internal Software Development
Allied Tube & Conduit
Posted 01 September 2003 - 13:23
This should work properly. Generate a log file of your update to see why the uninstall of the old version fails.
Posted 02 September 2003 - 12:05
I actually got this fixed over the weekend. I thought that by turning off the MinVersion and MaxVersion options in the UpgradePaths that it would get all the versions with the same matching Update Codes. Apparently this is not the case. Once I went back and added all the other versions it worked fine. Go figure.
Thanks for the assistance!
Edited by Daywalker46410, 02 September 2003 - 12:07.
Joe Cody
