I have a com dll. With my major release this DLL is not registered.
WIth patch i want to register this dll. When i compile IS package for the patch information about this Dll is added in class table. Information is added when i use " Com Extract at build " OR extract registry data.
While patching Major release MSI and patch MSI are compared. Since information about COM dll was not present in Original MSI i get validation warning Val 0015. " Class table contains new information. Patch become uninstallable"
If i remove the information from Class table patch can be installed but com registration fails.
Is there any fix for this issue ?
Amarjeet
Add content in Class table during patching
Amarjeet
, Sep 28 2011 12:05
Posted 28 September 2011 - 14:33
Actually, Val0015 warns that the patch will not be uninstallable, i.e. users will not be able to uninstall the patch to revert the product back to the un-patched state. This shouldn't be a problem.
Posted 29 September 2011 - 05:13
We do release patches after every 2 to 3 months. Many times its required that user needs to uninstall the patch and revert back to original product.
So i need patch to be uninstallable in any case.
Is there any way by which i can hide changes in Class table from patching mechanism.
One of the solution can be merge registry file. But this does not work for COM component.
I tried creating another component with different name but still same validation problem.
Posted 29 September 2011 - 17:49
Maybe you should keep your COM data stable between releases.
