I'm going to be distributing an app that uses SOAP and MSXML3, so I've been directed to using the merge modules for those files. Unfortunately, the guy doing the installer uses WISE, and I need to be able to reconcile the 2 systems.
I've used Orca to look inside the merge modules, but is there a way to actually 'crack' open the merge module, without rendering the internals useless? This is the only obstacle left for my project, and I'm learning as fast as possible about the MSI, but marketing are clamouring for fast results!!
Thanks in advance,
Matt
