recently installed Installshield Developer 7.01. I have created afeature
called BDE and linked the merge module to this. I run the config utility
and add a new alias with driver set to STANDARD. Then load the defaults and
set PATH=C:\ as a test. My problem is that although the BDE is installed,
my alias is not added. Some help would be appreciated (sorry if this is a
basic problem, i'm new to merge modules)
